HPro AI NVR is equipped with a powerful Unified AI container C/C++ framework, can support most AI accelerator.The system use HTML5 built-in GPU based H264/H265 video decoding technology, then can improve operator efficiency; The system use cross OS/CPU platform technology and then provide flexibility to deploy on x64/Arm architecture.
Support ONVIF camera integration with Profile S, also support NVR with Profile G/T, support H264/H265 encoding and G711/AAC audio.
Support token base API authorization, support HTTP/HTTPS. Video streaming encrypted with HTTPS.
The user-friendly Web UI and mobile source code are open, easy to customize UI, Expand the capabilities of your system to fit your organization’s needs.
The system support Linux OS (CentOS /RockyLinux /Ubuntu Debian/SUSE/Redhat)and Windows OS(Windows 10/11, Windows Server 2016/2019/2022) also embedded SOC such as RK3588.
Embedded SOC support device VO API for the video layer and GUI layer.
The system support S3 compatible object storage directly.
The system support HTML5 based video synchronous and asynchronous Playback.
The system ONVIF profile G based storage ANR, automatic recovery and resumption of recording following power loss or restart.
The system support user authentication and authorization with configurable access rights.
Support logging maintenance for alarms, events, operator activities, and system logs. support configuration capabilities for system settings and camera parameters.
