Based on the Electron framework, RapidVMS 7.0 has restructured its underlying architecture and supports RTSP/ONVIF ProfieS/ONVIF ProfieT /ONVIF ProfieG(future release).
RapidVMS is a community version of VMS software, with unlimited channels and no need for license.
If you encounter any problems during use, you can give us feedback https://community.linkingvision.com/ .
Download: https://sourceforge.net/projects/vscloud/files/
Guide: https://community.linkingvision.com/t/rapidvms-install-guide/15
Tips:
1. The default username is admin, password is Vision@168, you must change the default password first time.
2. Please download all the runtime support libraries from the following link:
https://linkingvision.com/download/h5stream/win/VisualC%2B%2BRedistributable/
Please install in order, 2008, 2010, 2013, 2015-2019. If there is an installation failure, please update the operating system in the System and Security check update in the Control Panel.
